Car maintenance not cheap, unless got money, every 5 to 7 years finish installment, trade in get new car, start all over again....hhahahhahaha
if do overhaul....
ill probably do a checklist like this:
1-forged conrod
2-forged piston
3-acl/king race bearing with +1 size than original (to compensate crank and/or conrod bearing wear/machining repair)
4-metal head gasket
5-new oilpump kit
6-timingbelt kit
7-oilseal kit
8-waterpump
9-pretty much all new silicon hose
10-get spare turbo (probably rebuild with billet compressor wheel along the way)
11-emanage to tune to new engine power potential
12-new fuel pump
13-new fuel regulator (adjustable preferred)
14-all new mounting
15-spare driveshaft
16-spare 3k for gearbox rebuild (usually tendang-gear simptom happens on high mileage mitsubishi) caused by worn synchro
thats it...
---------- Post added at 11:08 AM ---------- 6 hour anti-bump limit - Previous post was at 10:59 AM ----------
eeekkkkkk....
waittt..... why in the recipt lists item most of them twice?
#ubahsuai liner- rm700 ok
#grindvalve using machine- rm304 ok
#potong crankshaft- rm220 ok
#skim head- rm80 ok
#then again skim head- rm40???
#water test head+block costs rm200???
#change valve guide- rm256 ok
all the above machine shop charged already...then why below the bill still add another RM400 for the job paid above?![]()
if do overhaul....
1-forged conrod
2-forged piston
4-metal head gasket
5-new oilpump kit
6-timingbelt kit
7-oilseal kit
8-waterpump
12-new fuel pump
14-all new mounting
15-spare driveshaft
thats it...
eeekkkkkk....
#skim head- rm80 ok
dont forget......6% GST
---------- Post added at 05:22 AM ---------- 6 hour anti-bump limit - Previous post was at 05:19 AM ----------
heheheh, while at it, might as well do engine balancing and blue printed.....Baru syoik!
Budget increase oso nevermind, so long got evo monster engine inside.......
my overhaul cost me this on 4g93 na..
this is workshop bill only not include part that i buy my self..
so plan wise before you do major work to ur engine..
if do overhaul....
1-forged conrod
2-forged piston
4-metal head gasket
5-new oilpump kit
6-timingbelt kit
7-oilseal kit
8-waterpump
12-new fuel pump
14-all new mounting
15-spare driveshaft
thats it...
Pardon my ignorance and poor bahasa skills, but what is 'potong crankshaft'? You cut the crankshaft???
Dude.. you servicing your car or building a race car?![]()
Pardon my ignorance and poor bahasa skills, but what is 'potong crankshaft'? You cut the crankshaft???![]()
go for MSD ignition coil or racetech coil over plugs la but costs more (triple your budget)
Stock ecu can support?
My own experience using c.o.p conversion... it will lean out a bit of your fuel but not much.. but in exchange with better engine response
, ACL bearings, 4D68 crank, 2jz pistons, and bla bla bla). Head has HS 272 cams with WORKS cam gears. Injectors still 510cc and turbo still E3 16g. Good enough.....running in put max 1 bar only. Very takuts
How much you did for C.O.P. conversion?
To TS, I did my engine rebuild too at around close to 8k with engine balancing and etc etc. New original mitsubishi oil pump (freaking expensive, ACL bearings, 4D68 crank, 2jz pistons, and bla bla bla). Head has HS 272 cams with WORKS cam gears. Injectors still 510cc and turbo still E3 16g. Good enough.....running in put max 1 bar only. Very takuts
I can hit target 300whp I happy d without engine problems![]()
