Guys, need help here. Recently my car is experiencing pulling to the left side when i release my hands from the steering. Among other symptom that I felt are as per follows:
1) Car constantly pulls to left side when driving, either crusing, accelerating or braking. symptom becomes even worse when going uneven roads.
2) during braking can feel slightly freeplay in the left front wheel, like wobbling front and back
3) left rim feels slightly hotter than right side
4) when crossing road humps feel like front left wheel will bounce one or two times more than front right side.
Actions taken so far:
1) swap tires left&right - no difference but swap tires front and back got improvement
2) already went to check with three workshop on the brakes, three foremans says ok after checking but last I still insist the final foreman to service the brake piston just to be sure. foreman after service says brakes are ok,No difference compared to before service but funny the left side wheel still more hotter than right side wheel.
3) Both front lower arm changed with new sets brand 555
4) absorber also replaced new set
5) alignment done twice already at separate workshop
so what could be the reason for this? hopefully, some sifus here can offer some form of help and guidance.
Thanks a lot in advance.
did you have your drive shaft checked?
I used to have this issue too, and it was the left portion of the drive shaft that was damaged/loose.
the feedback I got, perdana tend to have this left drive shaft issue, and how to rectify it, is by getting a half cut evo 3 drive shaft, do some modification and then, its happily ever after.
Should your drive shaft really gone, another good consideration is to go for those blue silicon shaft cap.
Blue in color, its much durable as compare to the rubber design, hence longer lifespan for your drive shaft.
