He got twin turbo, can afford to use heavier wheels at rear. If normal FWD cars, FC sure affected badly.
Because the word "twin" means more power......lol
I used to buy my P1 with rare size
114.3 x 4, 8jj front, 9jj rear in temerloh, Pahang.
the seller's name is mamat temerloh, quite famous last time, now not sure.
rims are cheaper than those sold in halfcuts.
seems to be still active?
http://www.mudah.my/mamat-temerloh
Because the word "twin" means more power......lol![]()
Your offday all on weekdays. Weekend also you work?
Actually I don't know why danz is using larger size for his rear tyres considering his twin turbo is FWD.
Not really what. For high powered engines like those heavily modded RB26DETT or 2JZ-GTE, they tend to convert to single large turbo instead of retaining the original twin turbo setup.
If I am not mistaken, 6A12TT is using a sequential twin turbo setup. One big, one small turbo.
Missing one day?????![]()
, extra one day is split into OT.,
like that loh.
Like today, i start morning shift dy. 2 days of shooting, pointing in meeting.
sat, sunday...no gm, no goverment to monitor. Wahahaha...
work 4 days off 2 days. No fixed off day.![]()
yes, mine is sequential twin turbo, both small turbo, one big one small is parallel turbo, if not mistaken. like fd3s
better traction too![]()
That is the thing, twin not necessary more power. The way you word it like twin is so powerful....hhahahhaha
Bro renesis, is not fun work 12hr shift.
That is a long shift.
Actually what position you are in? Involved in the manufacturing plant there itself or office job?
involve in everything, cover hill, cover sea.
make wrong decision, just spare some fully full synthetic oil for next meeting
Not easy job at first, i work with team of 50.
Check my FB lahhh....
Same with 2JZ-GTE also. Also sequential. Since your engine got two turbochargers, that means if go for turbo servicing it will surely cost more?
Shouldn't better traction be given to the driven wheels at front?
Still considered as more powerful than most other 2 litre engines. 6A12TT got like around 240hp. With that power, shouldn't be a problem even with 245/45/17 at rear.![]()
well if u have 2 siputs.... that means double of something to jaga be it small or large, its still 2. same like hoe a v6 is more exp than an inline 4... you have more of some bits, double of some others.
if you want more traction in a straight line.... wider tires are to be given to the driven wheels
Bro. Danz referring to cornering force....hahhahhaha
Of course turbo more power over NA, but I am referring single turbo to twin....lol![]()
Even for FWD, rear tyre width can affect cornering force?
