The only reason why i'm driving this Nissan Sylphy which friends have named "STD" due to it's name similarity to Syphilis, is because I needed a family car to replace my bar-ed up, stiff Wira which for the life of me regret ever selling. Sylphy has tremendous rear leg room and huge boot space with weak-ass power because of the slack slow CVT gearbox which is the same GB found in the Proton Inspira. Interestingly though, the cars usable power range is between 3.5k rpm to 5.5k rpm. Anything before that is weak.
Again having said that - once you get started, the gearing is really weird. 3pm will bring me to 150km/h and 5k rpm is top speed 180km/h already. Red line is 6.5k. The pickup from 100km/h to 140km/h is pretty good. But getting to 100km/h is pathetic.
I'm running on non-standard size 17" and stock is 15" with the facelift model running on 16". The model I'm driving is the G11 model which didn't come with a CVT cooler and I managed to trigger limp mode on the 1st week of driving the car up Genting. After adding a CVT cooler I find out the unit I removed to install the cooler is a "CVT heater" which heats up the CVT oil to optimum running temp 55-60 deg Celsius so now it doesn't have the heater in place anymore the GB takes longer to warm up and until it does the car drives like a jackrabbit in heat. So I have to drive it slowly until operating temp.
I've been outrunned by a Alza and Axia on the NS highway going at my top speed and cornering in this STD is quite good considering I have swapped out 30% stiffer rear springs and using PRS customized Impul absorbers and have all the UR bars for my car. But the sheer weight of the car and the oversized rims means i still scrape the wheel arches when gunning really hard so conclusion is this car is not meant for chucking around or anything that involves speed.
FC is atrocious at 10km/L at best city driving and 13k/L for constant highway driving (top speed 120km/h). FC is heavily influenced by how clean my air filter is, so I need to clean my drop-in weekly and blow out all the dust and rocks inside the airbox picked up by the stock scoop.
I've spent a shit load on maintenance already all because of very odd-no-error problems which until today I don't know was caused by what (the problem dissapeared by itself) and have given up on modding this car. I've dismantled quite a bit of the car and replaced a lot of things already. I know now Nissan over-engineer their cars and have redundancy for everything. 2 x O2 sensors, 2 x catcons, O-Rings and gaskets for everything and if you don't swap out these o-Rings it'll cause a vacuum leak and everytime you replace the 100k km spark plugs you need to swap out 2 other O-rings.
Oh and nothing Nissan is cheap. NOTHING. Fuel pump + fuel regulator + fuel filter is one assembly and cannot be bought separately unless you mod the housing which is impractical. RM1800. Primary O2 sensor RM680, Secondary O2 sensor RM480, MAF sensor RM480, Intake Manifold gasket RM260, TB O-ring RM50, stupidass iridium (stock) spark plugs RM260 for 4, Driveshafts RM1800++ per side, Wheel bearing RM450++, Alternator RM2000, Engine mounting full set RM2000+ and so much more. NOTHING is cheap. And all these prices are non-original Nissan Tancheong prices.
Cheap car to buy used (40k max) but effing expensive to maintain.
