Wira Rear Lamp Question
Which means they can double up as brake lamp and night lamp at the same time?
Usually are like that even VR lights are like that. Some cars of course have separate night light and brake light especially newer cars fitted with LED.....
Mine got 2 bulb but not sure how to check if they are dual filament or not.
Need to taken out and see loh!
Single filament....5w for tail light, if 21w for signal light, some signal bulb comes in orange color
https://www.zerotohundred.com/forums/attachments/566002.vB
Twin filaments...... 21w/5w for brake/tail light
https://www.zerotohundred.com/forums/attachments/566003.vB
Oh, can see there are 2 things inside the twin filament. I need to check mine and see. When I took out the bulb, I din't notice any bulb for signal light.
Nope. Mine got 2 light bulbs in there. big one for brake light and small one for night light like this:
https://preview.ibb.co/jG1Lua/IMG_8179.jpg
Pardon the rust. This was before I clean it. You can't get this socket anymore at spareparts shop. :bawling:
As per bro. sanekit photo. Small bulb is tail light, big bulb is double filaments for tail and brakes....
attachment.php
As per your photo, signal light on top.....lol
For those fully lit even on braking, means the small bulb should light up as well? Because the small bulb is on the inner side.
Located somewhere else then. :biggrin:
Yes. and the big bulb is outside. signal inside.
I thought signal is on above these lamp? :hmmmm:
sorry. the small bulb is the night light. big bulb is brake light and night light. so at night, both supposed to light up and the big bulb 2nd filament will light up when braking. :adore:
So, for those that lit up on inner side upon braking, could it be that they changed their small bulb to large dual filament ones?
Fully lit means both bulbs are twin filaments loh......:driver:
This is one weird case here. Instead of brake lamp at outer side, this one is at inside while outer side is not lit.
attachment.php
the bottom white LED light for fun ?
Though F1 ON it during rain, but red color. Hehehe...
