40% die loh! how to drive take so much power away.......![]()
Everytime I pick up, I will off the air con.
makan petrol oso. lol
Can feel, even for VR I told you before I normally switch off the compressor......![]()
that's right, vr2 has spoken on behalf.
I guess its really a feature of older engine especially for mitsu.
the rotary compressor very hard to find these days for 4gx engine. Even halfcut ones are not that good. Recon compressor mostly are pistons type. I broke my rotary compressor previously and now i think i'm using the pistons type coz very damn sluggish if ac is on.![]()
Those lightened and dampened crank pulley?
Even for your powerful engine, you can still feel the power loss from air cond compressor?
Do these rotary compressor had any disadvantages compared to piston ones?
Sorry for late reply since just back from overseas..
Proton did not produce rotary type d.. only Miso boshi d..
Indeed that now you want to get one good conditions one like digging gold at seas d..
but rotary life span is short compare to piston type..:
ya. i'm talking about mitsu. LOL.
Compressor must take also, do high revs off compressor better.......lol
yup.. lighten all the pulley inside the engine can feel the difference but need to buy those whom got brand not custom made since it will not last long due to the material.
you can feel pulling when compressor is on except v6 since not much feel..
Rotary compressor got no repair kit, like normal parts.. last time me change my Kancil compressor like changing normal spare parts (1 year one compressor) since rotary
even rotary also can feel a bit of pulling when the compressor clutch is biting the compressor..
How about something like this one? Works or maybe Arospeed? Considered as trustworthy?
i high revs compressor on. but :slug::slug::slug:![]()
add boost inside the car d.. more cooling..
Some say light weight crank losses some torque......
yes.. as long as got brand and must T6061 aluminium since very hard aluminium..
Here's a video of my idling when air cond compressor is kicking in during hot afternoon. The RPM seems to be dropping to 500rpm and rises back up again when it reaches that low. I also tried to see how many RPM that the compressor drains away during hot afternoon and it seems like it takes away almost as much as 1000rpm when it is kicking in.
https://www.youtube.com/watch?v=sn5uvJciAmY&feature=youtu.be
RIP throttle body.
Several mechanic told me that is the case too. So, idling control is not working properly?
Maybe I can consider this as next upgrade for my car since this is not very expensive.
