I'm due to overhaul my brakes.
My car is an 07 1.3ezi with stock calipers and rotors.
Can I change to the 1.5 18mm rotor while keeping the stock calipers?
I dont think its compatible. You should change the whole.
1.5 calipers are now 400 bucks each.
Anyway I ordered AR racing 16mm version rotors and steel braided hoses.
Pads I am planning to use sumitomo.
You never said whether yours is the 1.3 or 1.5? If 1.3 swapping to the 1.5 Myvi calipers and rotors. it's plug and play for the 1.3. It's a big improvement for the 1.3/1.0.
If yours is the 1.5 then you'll need to find a customizer to custom make the bracket for any caliper you want to fit on. Wira 1.5 / GSR / Mivec one is cheap to buy and fit. Hondas are a bit more expensive but work great. 2-pot / 4-pot are overkill and expensive and will more likely force you to swap to bigger rims.
mine is 1.5. The mechanic recommended to change to Honda Odyssey with the condition rim has to be upgrade to 15 inch too else will not fit. is that true?
just drove from jb to kl and back to jb last week with my stock tyres and brake pad. Was actually more manageable than I imagined.
