1jz E36 BMW frankensteining
getting there. Gonna fit a top feed injector with fuel rail. More modern tech for the old engine.
That's the cure or workaround but what's the cause? Is it because 1JZs are difficult to start in the first place?
This ECU came with the car? What happened to the original 1JZ unit? Just curious. Since you are scaling back, why didn't you revert to stock turbo, injectors, etc since they are supposed to be more reliable?
What drugs are you on? Do you have cat's eyes? I had to magnify and stare for a long time. Still cannot see it totally.
I can see the plate if I look at it from another angle at my monitor. If i look straight, I can't see but if I look at my monitor from top, I can see it.
Lol . .what monitor do you have? I still cannot see.
Edit: NVM. I shifted the image to a different monitor. It's quite evident now
It all boils down to cost. I would need to buy all of that and that would be a small sum, then I'd need a tuner to reinstall all that and remove all the mods and retune the whole thing. Mechanically like I said this car is sound so might as well put my money making it more comfortable. That was my initial thought.
Now I'm thinking why didn't I just buy stock.
Dammit.. gotta go edit that pic again
ok you really shouldn't be able to see the plates now
Hahaha, actually if regular members here know about the plate also shouldn't be much of an issue. The real risk and danger lies on strangers and visitors here.
