That's the cure or workaround but what's the cause? Is it because 1JZs are difficult to start in the first place?getting there. Gonna fit a top feed injector with fuel rail. More modern tech for the old engine.
how long will it be featured here or in RnR
Couldn't the ECU's cold start program be adjusted to accommodate this?Non-standard ECU problem.
What drugs are you on? Do you have cat's eyes? I had to magnify and stare for a long time. Still cannot see it totally.
Lol . .what monitor do you have? I still cannot see.I can see the plate if I look at it from another angle at my monitor. If i look straight, I can't see but if I look at my monitor from top, I can see it.
Edit: NVM. I shifted the image to a different monitor. It's quite evident now
Oddly, I have 5 monitors. Only the TN unit was able to view. Other IPS cannotLG desktop monitor, lol
This ECU came with the car? What happened to the original 1JZ unit? Just curious. Since you are scaling back, why didn't you revert to stock turbo, injectors, etc since they are supposed to be more reliable?
You all on CSI ah?.....lol
really csi, 5 monitor ...
got one view side way.![]()
ok you really shouldn't be able to see the plates now
Hahaha, actually if regular members here know about the plate also shouldn't be much of an issue. The real risk and danger lies on strangers and visitors here.
So when is the big unveiling and TT?
