OCD people should never buy used modified cars.
Lesson learnt
Still can la, just not so extensively modified! Light mods still ok coz can fix easier and faster.OCD people should never buy used modified cars.
Lesson learnt
But following what he had done, got many issues.....Yup, seems excessively long since it was kinda road worthy prior to this
Lol .. .progress report please. Dont keep us hunged in suspense.
Even when titillating, must show some flesh also.
Intentionally cut off?Right now, the flow of the coolant within the block was discovered to be cut off. .
But 6 months pretty long time woh!....All the best on your build. Slowly but will get there soon.
This one baby monster.....hhahahhahha9 mth for baby. So ...another 3 mth to go yo..![]()
Right now, the flow of the coolant within the block was discovered to be cut off. So the back of the block is not getting any coolant flow. The engine needs to be lowered a bit to access the return at the top of the engine (it's situated right next to the firewall). So yeah. Sigh.
Nah. This could have been a super heavily modded engine and I'd still consider it if I know the owner was as OCD and meticulous as me. There are two ways of modding a car :
- The proper way
- The skimp and cut corners way
Regardless of heavy or light, if it's done properly it's still a decent consideration. Guess which was mine.
Actually I have heard this on forums , where they completely block , but yeah now I realize its stupid.wahhhh that one is for the heater is it? usually people just install a hose to bypass only, not completely block!
Some cars actually can be just blanked off, depending on how the internal water channel designs are, some can't. Either way, the job itself is horrible! Most people use a blanking rubber cap, wtf is that photo? It's like the ends are glued and then crimped?![]()
Basically sum up the end result finishes of the car build by the previous builder itself. "As long as it works " method.
Izso finishes is showroom worthy![]()
Why dont they just weld and connect the 2 pipes together? Or connect with a flexible pipe?
brand new koyo radiator for R34
