Guys, I have some problem, after some investigations:
- usually when temperature passes half, radiator fan will on and once the temp is slightly below half, it stops
- problem is, sometimes even after half, the fan is still not moving causing the temperature raised high (almost red bar)
- i thought the fan broken, tried to knock the motor (suggestion from a friend), still not working
- but, when I turn the AC on, both fans (radiator & AC) are on now. Meaning, my radiator fan is working! It is just maybe the sensor of telling the fan the temperature is high (more than half) is problem maybe?
- this is not a problem when on cruising, temp stays at 1/3, but when stops/traffic jam, with AC off, temp starts to raise. So, to temporarily solve it, I need to turn the AC to keep the temp low.
please, any inputs?
please, any inputs?
They tried to put the blame on my tuning but did not even bother...
