Guys, I have some problem, after some investigations:
- usually when temperature passes half, radiator fan will on and once the temp is slightly below half, it stops
- problem is, sometimes even after half, the fan is still not moving causing the temperature raised high (almost red bar)
- i thought the fan broken, tried to knock the motor (suggestion from a friend), still not working
- but, when I turn the AC on, both fans (radiator & AC) are on now. Meaning, my radiator fan is working! It is just maybe the sensor of telling the fan the temperature is high (more than half) is problem maybe?
- this is not a problem when on cruising, temp stays at 1/3, but when stops/traffic jam, with AC off, temp starts to raise. So, to temporarily solve it, I need to turn the AC to keep the temp low.
please, any inputs?
please, any inputs?
This is St. Regis Residences Carpark along the Orchard Road. Read on and feel the pain...
