Below could be the issues;Hi guys,
I have a bog problem with my headlights. The lights are very dim. Can barely see the road while driving at night. The bulbs always blow.
Any advise on how to make the light brighter?
Your description of the problem is too generic. You need to explain a few things to us :Hi guys,
Been using my VR for many many years. Then wife bought Chery SUV the lights were so much brighter so when use back VR looks so dim. Now wife on Forester with LED headlamps, my VR headlamps like cannot see anything......lol
If VR need upgrade will look for you.....my foz also into that category..cannot see anything...
hence retrofit job done and now happily driving touge road nighttime![]()
Fit LED projector unit into old headlamp housing.....lolWhat did you do exactly? Retrofit the std headlight bulbs to LED?
My son's Swift came with aftermarket projector headlights and the quality is crap! It's still using normal bulbs despite the projector housing then the wiring inside the left one is already a bit loose so it can go off suddenly (just luckily this last few weeks still can turn on all the time). The brightness is just substandard. The DRL rings around the projectors are all already gone off, not sure if also wiring issue or really spoiled ring lamps. The clear coat already peeling off, so I had to wet sand them to remove it completely then reapply some clear coating to make them look clear again, but some section already have cracks which I cannot do anything anymore. I've replaced the bulbs with better Osram bulbs so improved a bit but still substandard brightness. We're still using it coz my son likes the look but maybe later once he's bored then we'll change them back to the original stock headlights (they still look very nice and new!).
*keyword: aftermarket headlights....
those always comes with shitty projector even those famouse "something eye" brands and so on....
thats why i opted for most projector unit from oem headlights...
alternatively... i can help do projector swap from those shitty projector and replace them with better oem projector for full lighting performance.... :![]()
Yeah those aftermarket ones are all lousy China stuff. Those who had changed projector headlights for the Swift did complete swap using the original Swift Japan projector headlights, just that those don't have DRL rings like this aftermarket shit (which is already dead anyway on mine!).
Oh you can do that?? Hmm never mind lah, I won't spend anymore on this crap. Later will just swap back the original ones and just try sell the aftermarket ones.
haha atleast if your son insist to keep the projector design headlight...no harm doing the projector swap...![]()
