What?It sounds crazy. I am thinking to clean/flushed the engine of my 100K km mileage myvi by changing the EO again after the second day of changing EO.
Do you think this will work or waste of EO?
A waste if u have been changing the oil regularly.It sounds crazy. I am thinking to clean/flushed the engine of my 100K km mileage myvi by changing the EO again after the second day of changing EO.
Service mostly according to mileage and timeA waste if u have been changing the oil regularly.
Anyway i have been changing semi syn oil at mileage of only 5k km and fully syn at well below 10k km. Thats a waste too as it can still be used.However Tesco is selling oil at cheap price so i really dont mind.
Monday Change EO and oil filter, tuesday change EO again. My mileage daily about 100km.What?
meaning Monday - Change EO and filter. Tues - Change EO and filter again?
No point. If you're gonna do that - might as well run it for about 100km before the change. Or flush with Royal Purple oil during your oil change.
wow. car wont be heavy ar using Diesel EOjust use higher quality oil in slightly shorter interval than usually recommended...
that would fine enough...
OR
like me...i'm using diesel engine oil in petrol car...its really clean internally
That's not what I wrote la.. I said flushing with Royal Purple oil. Super high detergents amount in their formulation. Using expensive fully syn oil to flush. HAHAFlushing with Engine Oil Flush. heard alot of bad stories when googled
What's the point and what do you hope to achieve? Recalibrating the butt dyno? Bear in the mind that the filter which you choose not to replace, contains a fair amount of tainted oil.Monday Change EO and oil filter, tuesday change EO again.
Out of curiosity, did you open the oil filler cap and see a lot of muck, sludge or varnish in the engine?okok. thanks for all inputs, looks that regular change intervals / maintenance is the best.
Thanks
varnish yes.sludge mildOut of curiosity, did you open the oil filler cap and see a lot of muck, sludge or varnish in the engine?
seriously?varnish yes.sludge mild
If you have discernible sludge, might I suggest maybe an actual engine flush or even try diesel EO ?varnish yes.sludge mild
every 10K from Perodua SC, Sometimes we got the semi oil and sometimes fully.seriously?
Whats your oil change interval all these while?
My campro got no sludge at 100k, only some varnish due to high revving action.
mind share what brand ? uncle VR pakai, bro pomen also pakai.just use higher quality oil in slightly shorter interval than usually recommended...
OR
As mentioned initially thought of using for a while only, more to flush the engine, but engine became more quiet so I continue using. Now already use for a few years already and oil is cheap. Around RM80 for 7L......lol Mine is Pennzoil 15w-40mind share what brand ? uncle VR pakai, bro pomen also pakai.
! who can help me!!!!!!!!!!!!!!!!!!!!!!!!where the workshop can help me repair!!!!!!!!!!!!!!!!!!!!!!
