Restoration of Satria 1.3
cIvIc_noob
Miri
Hi guys,
i have a one speed all the way wiper problem.
I've even bought and swapped out the whole wiper/signal control. problem still persists.
I read up more and it says could be a relay problem, could someone point out to me with a pic of the relay location?
i PM'ed a seller at shopee, mentioned that normally it is at linkage, I don't think so from my googling. So i went to look at the wiper motor side but couldn't find it.
I looked at the fuse box and i am confused.
So where exactly is it?
Hi guys,
Switch on your wiper or turn signal and listen for the relay 'tik2' sound. Trace the origin for that sound and you will find it.
I think its at driver side under the dashboard. It should be visible when u peek from the bottom.
Hi guys,
Engine bay I think. That's the only place that has those large relays for Wira.
Hi guys,
it's inside the fuse box under your steering column. the box supposed to have a label on the cover.
Fuse box got relay? I think what bro. Izso mention in engine bay, the main fuse box have relays in them.....
Key ON (not start engine), Activate wiper, listen to which relay clicking/ feel by finger. I use this method as last resort.
Hi guys,
Manage to find it?
Thanks for telling Me there are relay there, but i Dont hear tik tik tik sound when i turn the wiper on.
Is there a possibillity if there was no relay there in the first place there wont be tik tik sound?
Doesnt seem Like it bro , i googled the relay pic , And i Check engine bay Area at the small relay box on left And also the fuse box on right , nothing looks Like it .
Oh use finger, haha ok i try find with This technique, but i am afraid if the previous owner removed it then there wouldnt be tik tik sound
Where art thou, wiper relay? Pls magically Show yourself tonight when i Go back home to search for you
There are such pics on the internet but are you sure it's not for rear wipers?
You mean the relay wiper pic i uploaded above is rear? Cannot be eh, i Shopee And lazada wira wiper relay , all came out 6 pins. Like the above
Try this one. It may be it
Looks very probable bro, tonight i go check it out, that day i took picture macam nothing there, but there are a few loose connectors here And there too. So tonight i Go Check if anything there. The wiring below is a nightmare.
By the way do you happen to know whats that missing piece of relay is for? The One on the relay board.
