Have checked your rims for dents, are the rims fitted to match the hub perfectly, if not may need the center cones. What about wheel balancing, and last resort on wheel balancing. Oh, there is a new balancing method too, road force balancing......Hello.. I am from future.. Hahaha.. Alsi having this problems. Vibration during 60kmh-100kmh..already changed rack j end tie rod end, allignment 3 times, replaced longshaft..
Will try to swap rim with my friend. Yeah.. I also put 1 pcs spacer each rim. Will try to remove them. Tq broHave checked your rims for dents, are the rims fitted to match the hub perfectly, if not may need the center cones. What about wheel balancing, and last resort on wheel balancing. Oh, there is a new balancing method too, road force balancing......
Try without the spacers and if still not fitting, fit in center cones.......Will try to swap rim with my friend. Yeah.. I also put 1 pcs spacer each rim. Will try to remove them. Tq bro
Tried out removing spacer. Vibration still appear.. Will inspect the rear differential. Huhu.. Pening already..Try without the spacers and if still not fitting, fit in center cones.......
Balancing done, last resort on wheel balancing.........Tried out removing spacer. Vibration still appear.. Will inspect the rear differential. Huhu.. Pening already..
Did you use a center cone for your rim?Tried out removing spacer. Vibration still appear.. Will inspect the rear differential. Huhu.. Pening already..
Have seen a few in PJ also, these are really experience people. But for me, now I prefer off wheel balancing. If need to remove wheel for some repairs later fit back less hassle. On wheel, most of the time even mark back same lug place still tent to run a bit.....lolIf all else fail, head to Rahang lama and find Ah Ching or Ah Cheng shop to do on wheel ballancing. I do believe there are others specialist nearer to u but this is the one that i know of.
Did that for my blm after few tire shop fail to solve vibration issue. This was more than 5 years ago. Was kinda shy when i arrived as i drove the cheapest and superstock (by a large margin...very large margin) car to the shop...hahahahah.
What i notice was that he spins the tires much faster than other tire shop and he feel for vibration using his hands by placing his hand on various parts of the car such as bumpers, absorbers, etc.
Use center cone every wheels..Did you use a center cone for your rim?
Did you manage to figure out the vibration?Use center cone every wheels..
Not yet bro..try to replace rear axle oil.. Also no differ.. Or my rear axle is LSD and i out non LSD oil? How to know whether rear axle is LSD or not..Did you manage to figure out the vibration?
