Finally getting rid of my 4g13
91 engines have gone up in price suddenly. I remember finding them for as cheap as 1.8k before first MCO. Anyways notes taken, still searching for a halfcut 4g92 but at the same time a 91 set and a turbo as a backup plan.
Quick question: is it that the 92 mivec cannot be endorsed on a 1.3 body because its 'mivec'?
huh.. 30% increase is your max. They don't care mivec or not. 4G92 is a 1.6L so 1.3 + 30% capacity is approximately 1.7L so plenty of space for your upgrade.
Remember to upgrade suspension and brakes....lol
Go halfcut search. Take ur time. This thing cannot rush or u end up too many rojak ideas.
Go for 92 mivec. Price also keras.
If rojak total to that amount of 92 mivec, no point rojak.
Rojak scare some parts not matching, probably need more tuning too. Halfcut all just transfer over....lol
for sure.. the hunt for the 92mivec is still ongoing. as mentioned previously, will try my best to keep this thread active as much as i can..
Update on the thread,
for now im just sourcing some other parts like radiator, suspension and better brakes. Have posted in various groups asking if this engine can be found. Hunt is still ongoing
i also need to know this. How and where do we check to see this line to identify what engine we are dealing with, and what about the 92 series engines?
Make friends with your mech and get him to help you check (assuming he knows how to identify). The problem with halfcuts is you'll never know what you're going to get and how much will be needed to fix up the engine before transplanting.
this can only tell you what head it has. On the head, right infront, just over the extractors.... if i remember correctly on its right (facing the car)
block u pandai pandailah....
i hope you know what ur doing, i didnt mention this earlier but i believe one of the links posted by you was that of a newer generation engine, which means its not practical to put into the older protons. thats why its cheaper, cause not much demand.
**take note the newer gen 4g cannot rojak with the older gen parts, its 'terbalik'
Understood, take your advice also. I'm making sure the engine is from the CK or a mirage itself la to save me the headache.
ck is the 'terbalik later gen ya'
mirage refers to the whole range older and newer range...
the engines look diferent, should be easy to tell apart
