hi there every1...
i just got my 4g93 + MIVEC head done last week...
it feels great with the ported n polished head...even with my stock pistons...10.5:1 comp ratio
did a top overhaul before installation...changed all the valve seals n grind the valves...this is my 1st time expose to mivec internals...it's kinda complicated...but it's good to understand your engine well...i enjoyed carrying out the mod.
if u really want more power...slot in the mivec hi comp pistons...stock mivec comp ratio 11.0:1 but in 4G93 block it will be 12/12.5:1 as the stroke is longer.
as i know...pistons...conrods...n crankshaft has their own balancing...so this is the reason y i nvr use the mivec pistons. up 2 u man.
i'm driving satria GTi...
just have to use the whole engine wiring...which nvr go through the fusebox...mivec 7035 ECU.
the front cut i bought came with 2 way LSD close ratio transmission...Racing flywheel...custom air intake piping with K&N air filter.
2 way LSD...not good for town driving & high speed. close ratio...u'll pay 4 the fuel...but the acceleration is there...i noticed that it's a bit hard to gain speed after 150km/h at 4th gear...what i think is because of the 2 way LSD n the racing flywheel. Do u guys agree?
if any1 out there going to perform this mod...better buy the MIVEC half cut...then fit all your unwanted stuffs back to the mivec engine block n sell as a normal 4G92...with 1.8 head, gearbox, wiring n ECU. the mod will be more complete.
i'm located in JB...Malaysia.
oh yeah b4 i forgot...u need a set of EVO 4 timing belt 1st...because 4G93 block is higher....so your stock timing belt can't fit in.
Regards,
Regards,
