Civic SO4 undercarriage - what to check?
If kluk kluk sound most probably came from your tie rod part...a bit easy to check if you had car jack. Jack up your car and then try to shake your rim. If there is a small movement(read not fit) almost sure cause by that tie rod part..
If the sound ngek ngek..maybe that from bush..
My previous problem came from brake caliper..suppose to be a plate at the pad..but the plate was missing..cannot get replacement..so, my mech put greese..problem solve :D but make sure don't put the greese onto your pad or disk...
if jack up and the rim shake, get ready mate, it'll cost u rm400,for the (lo ko tui) and the rubber casing, original honda parts and not including workmanship, i just did mine. better use ori part, a bit xtra,but more reliable and lasting.
RM100 (more or less) is for all the bushes at the rear or only for 1 bush???
sorry, no experience and knowledge in those bushes thingy. pls enlighten me.
rm100 plus for each, and if u change better change both, its more advisable. theory of balance, hehehe
I got that part. Just used for one month (for SO4). Now using SR3 part. part still in good condition(almost new :D). PM me if anybody interested
