- Joined
- Feb 23, 2006
- Messages
- 257
- Points
- 1,516
yo,wirase dnt have any lotus tuned handling the suspension system is da same since the earlier wira's lotus have nothin to do wit wira handling system,wira se handling sucks coz da body is 2 heavy and the weight balance is improper da car i drove spin 360 uses added antiroll bar michellin tyres and alignment is perfect,jst had it done mitsu never came out with a sedan hatchback only the satria so protons design on weight balance in da wirase is not perfected.Maybe stiffer shocks will improve it and slight extra negative camber will improve the handling at the rear bt tyre wear could be tramendeous. The only proton with tuned handling by lotus is the satria gti dat also the suspension system arms and all is reused mitsu design lotus only improved the chassis regidity with monoque system for the chassis so less roll when entering corners dats why satria gti is stiff.
