opposite fellows oso get shock..... hantu mari..... ekeke
taikor..the spacer i use is the one u give me....let me see what is the effect when i remove the spacer....
last night i have check the abs....TITAn screw it nicely....tonite will check the spring...maybe the spring got problem...
thanks for the advice..
butty....i still wait for u leh..where are u?
really...then i will check with him liaw...since now i face this problem and the bar cost RM250 to RM300 second hand leh....so DIY is my option...function off course will function but quality wise u need to check it out yourself.
taikor...how much u get that bar?i found the word. its call lateral rod. do not modify from yr original 1, material is too soft.
mine its custom from a toyota steering rod. need to adjust long short mah.
taikor...no problem...not much car to see...but saw HAnnah Tan Nia.....hehehee....alamak miss again haih! Erin kena throat infection,the side effect after high fever last week, so i think i can't join u guys already.
can anyone give a hint...thanks...
