SW20 Oil temps
MindFreaker
Hi guys may i know whats ur oil temps and speed when travelling on Nth Sth Highway?
my oil temps are at 120degrees @120km/hr 3000rpm,
the temps seem way to high anyway of reducing them?
i know that my stock oil cooler lines have been removed
but is there anything else that has problem for the temps to go this high?
Mine runs about 110C. I believe the max it should go is 130C. Whenever going uphill like Genting, there was once it climbed close to that.
How long were you running at 120kmh before it slowly climbed to 120C?
Also, are you still on stock intercooler? Changing it helps as it reduces intake temps.
using Greddy Intercooler with a spal fan pulling the air, as for temps it took me fairly quick, like 10mins and i started seeing 120degrees, so the whole time i was regulating from 80km to cool down and 120-140km to speed up, lose to aunties driving kenchil , damn tortureous journey, hope to get some help pls, so far seems to be having problem on getting workshops in spore to fix up a oil cooler, all the same excuses, no space, wah very hard, sorry cannot do, any bro that has a oil cooler care to share experience? does it reduce at least 20 degrees?
Before you fit your oil cooler make sure you get an old pressure meter and keep your pressure up. Failing to do so will damage the engine prematurely
ya i got oil temp, oil press, fuel press, water temp, and boost gauges in my car, but now the problem is lots of workshops are rejecting me in installing an oil cooler because it is difficult, 95% of workshop here sucks
its easy wert, do you have the adapter for your cooler / oil filter?
You can come JB ZT Power to install the oil cooler. :shades_smile:
But you need to get the oil cooler kit 1st.
Hmm..I have oil cooler installed and also an oil pressure gauge but no oil temp yet...Might have to get 1 from Sg soon.
I have a spare oil cooler set if you'd like to try if it works..
whole set? got pic? now i in selangor until thurs can pm me ur hp then i try to arrange how i can collect from u?
need filter relocation kit? or just the normal sandwich kit ok?
and where is ZT ? i not familiar with JB, i give up on the stupid singapore workshops already
ZT Power is in Mount Austin
But no worries just give me a call when you in JB. I will bring you there.
HP 012-3711210
HP 012-3711210
oooh thanks but 1st i need a oil cooler 1st, i heard there's a white mr2 in jb, are u him?
White = Meister2
I am driving the blue one.....
Just give me a call when you in JB.
Cheers....
White = Meister2
Cheers....
ok , what i be doing is to order from USA online, but do i need to get the filter relocation kit or just the normal sandwich adaptor will do?
