need advice...gsr on evo gb or gsr gb?
guest
Kota Kinabalu
i do really need advice...im using auto gsr now and wan to convert manual gb...wat is the BEST! g.box for my gsr?gsr gbox ok?or evo ok?how about evo3 gb?some say evo3 gb not really perfect for gsr except for evo 1 n 2...so what is the pro and cons using evo gbox..and same also gsr gbox?help guys..
whats the application? street normal use? highway? drag? circuit?
im somtimes drag also..so street use=35% highway =30% drag=35%...i saw my friend evo 2(4wd) loose to gsr...the said its because of the driving style and gsr have better ratio..is it true?i only wanna consider using evo and gsr gearbox..no for 1.6 mivec gb....any pro and cons on using evo gb?im asking this becoz i heard my of the gsrian using gb from evos....help..help
i used both gsr n evo gearbox on my gsr engine quite a while ago. gsr's 1st n 2nd gear feels stronger compared to evo gears on gsr engine, and evo's 3rd, 4th n 5th gear is simply awesome and unbeatable!
i noticed better fuel economy after changing to evo gearbox, better top speed as at 5th gear, the revs are lower compared to gsr gearbox...
so its up to u bro...
ohh but i tot gsr 1,2 gear r lame...and 5th gear for evo are very high rev bcoz of its short ratio...110km more than 3.5rpm?evo 2 and 3 gb are the same?
