warao, warrenty not yet kau tim already change the suspension, izzit more comfy or bouncier or the same as now?(stock)
--> Enhances the comfort and increases road handling
the undercariage lift kit is the one that changes all the suspension and absorbers and also adding those stuff to push the whole undercariage up,maens more ground clearance...the body lift kit is the one where they just lift the body up butthen mantain the ground clearance of the car... this is the common mod if the person wanna install bigger tires cause its also cheaper than doing the undercariage lift... so what i was thinking was the undercariage lift kit cause it pushes the whole car up and gives you more ground clearance, butthen the mech i asked qouted me around RM3k plus for everything... so since im still not working full time yet cause im still persuing my studies, so i scrape the idea of it...
--> No matter how high you lift the body of the vehicle, your axle still sits nearest to the ground unless fitting in a 35" or larger tyre ..
Mine fitted with suspension lift, costing in the region of RM5K++ replacing the torsion bars, leaf springs and all round shock absorbers adding an approx. 2.5" lift to enable slotting in larger tyres, maximum 275/70/16 .. RM3k plus is dirt cheap but what components are they giving?? You can upgrade step by step .. First shock absorbers .. Later leaf springs and finally torsion bars ..
Body lift costs approx. RM2K whereby slotting of PU blocks between the body of the vehicle and the chassis .. I personally do not recommend bodylift kit for road going vehicle because it alters the center gravity of the vehicle, unless you are building a show car street truck .. Body lift is not the common practice for pple wanted to slot in larger tyres simply because of the cost, extensive modification to lengthen pipings and in Frontier's case, the modification needed to lengthen the steering driveshaft .. Not to mention you have to leave the vehicle at the workshop for 4-7 working days ..
ooh so we have a bleed valve... heh heh heh, you think can install blow off there instead of the bleed valve huh? those atmospheric blow off instead of those you plumb it back into the airbox type? =þ somehow i feel like if our cars can have that sheew sheeww sound also nice hor?
--> Standard diesel engine like ours can't install BOV due to low air pressure .. I've seek consultation from experienced mechanics ..
