I've been reading up plans of water-powered cars/water+fuel cars for the past few days. I was skeptical at first cause I knew that you couldn't get more energy than what you put in at the first place. The terms "overunity" and "resonant frequency of water" are being thrown around a lot.
And if you check out youtube.com, they have videos of a car running on hydrogen ALONE! It is possible but you have to put a coating of ceramic on your pistons and change your exhaust to stainless steel.
Word is they use a circuit to generate the resonant frequency of water so that less energy is required to split water. I'm not sure how this works in theory but it works. The voltage required is only 1.5V and it draws around 1-2 amps.
I'm doing some experiments of my own. Will post the results here as soon as I do it. Here are the plans is you guys are interested: http://www.keelynet.com/energy/waterfuel.htm
c-ground, jswong, you guys hold PHDs in physics and chem issit? You guys know damn hell lot of stuff. Hahaha
Lookin for ceramic coating services? CERAMICO si the best solution to control the heat and lubrication.
cheers...
