- Joined
- Apr 18, 2006
- Messages
- 3,677
- Points
- 1,663
what u mean by gear coverage?? i still catch no ball![]()
Gear coverage means the usual gear coverage from xxxxrpm to xxxxrpm when you shift at redline.
For example, you notice that while dragging, you don't really use the torque at 1-4K, even at first gear if you can launch at very high speeds. (40Kmh launch = starting rev for 1st geat is at 5K plus!)
if you drag, you will notice that 2nd, 3rd, 4th 5th, only involves the power in the 6-9K range.. depending on your ratio and peak rpm.
The only time you use the revs below that is during normal driving.
