try to adjust this thing...FICD something...
there's a alen key screw near the "cut-out" hose...adjust it...
please also make sure your TB is in good condition...
for toyota what is it called aaa ???
a bad compressor also make ur idling bad (during air-cond on)...
please do check all the air-cond fuse too...
Vacuum Sensor or Throttle Sensor maybe. But before change the item make sure check throttle body.
I have this kind of problem after installed SVT, now it's OK after done step above.
hahhahah.....
i have AFM for sale.
how to maintain d AFM in good conditions? want v need 2 do 2 avoid faulty?
can d AFM be cleaned o serviced?
If you have done throttle body and then it still not OK, it should be the sensor.
replace the sensor and then finish. unless something wrong with compressor.
also, try replace the tube from upper to lower vice versa, and turn the key below.
if nothing works, that means the sensor really busted.
