RX-7 Used/New Parts for Sale - Part2
RERider
Putrajaya
Updated on 22/12/2011
Clearance SALES. Offer me!!! Call to get best offer!
Engine related parts:
1. Border's Burnout Intercooler with Piping. RM1700
2. Engine Harness + Dashboard Harness. RM1500
3. Power Steering Pump. RM150
4. Air-Con Pump. RM200
5. Starter. RM150
6. Manual Transmission Gearbox. RM850
7. Master Cyl. Servo and Brake Pump. RM350
8. RX-7 Stock Intercooler with piping [3 units]. RM200
9. HKS Twin Intake adapters (w/o filters). RM150
10. RX-7 Strut Tower bar. RM180
11. Washer Tank Motor pump. RM60
12. RX-7 Stock Radiator. RM450
13. RX-7 Oil Cooler. RM180
14. RX-7 ATF Cooler. RM180
15. Water level sensor. RM40
17. New NGK RE Spark plug 8 & 9. RM300/set
18. Aluminium Heat Shield. RM30
19. FD3S Auto Transmission + Starter. RM1000
20. 4.1 Final Gearbox. RM800
21. Rotor Housing, Rotors, Side Housing (Good condition, ready for 3 complete engine to be rebuilt). Call
Body/Exterior:
1. Rear Trunk/Boot with Windscreen. RM1000
2. Front Windscreen Moulding/Rubber (New). RM300
3. Engine Bottom Diffuser/Splashboard. RM200
4. Rear Windscreen Moulding/Rubber (New). RM350
5. Front Fender Signal Lamp L/R. RM30
6. Stock Rear Bumper (with all brackets, bolts and nuts). RM400
7. RX-7 Stock Pop-Up Headlights with Motors (1 Pair Full Set with Covers). RM700
Down pipe and Muffler
2. Aftermarket 3" Downpipe. RM300
Suspension & Brake:
1. Front Upper Arm LH and RH.
2. Knightsports Front Antiroll bar (Thicker than stock). RM300
3. FD stock absorbers Front & Rear. RM150/pc
4. Front Disc Rotors L/R (Drilled). RM150/pc
5. Rear Disc Rotors(Drilled). RM150/pc
6. FD 99spec Front Disc Rotors. RM280/pair
7. Front L and R Lower Arms.
8. Rear Crossmember.
9. Rear LH Upper and Lower Arm Set (4pcs).
ECU:
1. Stock ECU for Manual (92-95). RM350
2. Stock ECU for Manual (99-02). RM600
3. Remapped ECU for 99-02 Model. RM650
4. Stock ECU for Auto (4 head socket). RM350
5. Mine's ECU for 92-95 (4 head socket, 300ps at 0.9bar). RM650
Others:-
1. Stock Meter Panel (Manual). RM450
2. Dashboard. RM500
3. Air Con Blower. RM100
4. http://i286.photobucket.com/albums/ll87/Joewek/Performance%20Parts%20for%20Sale/RX-7%20Member%20Brace%20Bars/DSCF0890.jpg RM1500 (Chrome)
5. http://i286.photobucket.com/albums/ll87/Joewek/Performance%20Parts%20for%20Sale/RX-7%20Member%20Brace%20Bars/DSCF3430.jpg RM400
6. http://i286.photobucket.com/albums/ll87/Joewek/Performance%20Parts%20for%20Sale/RX-7%20Member%20Brace%20Bars/DSCF3439.jpg RM250
7. http://i286.photobucket.com/albums/ll87/Joewek/Performance%20Parts%20for%20Sale/RX-7%20Member%20Brace%20Bars/DSCF3434.jpg RM100
8. http://i286.photobucket.com/albums/ll87/Joewek/Performance%20Parts%20for%20Sale/RE%20Engine%20Oil%20Cap/DSC02630.jpg RM280
Doors:
I have 3 pairs of RX-7 complete door parts as follows:-
1. Door panels/trimboards for LH & RH (3 pairs). RM250 each side
2. LH/RH Side Mirror. RM100 each
3. LH/RH Windows Glass. RM100 each
4. Power Window Switch (Driver Side). RM250
5. Passager Window Switch. RM100
6. Door Rubbers LH/RH. RM50
7. Door Handle (Both Side). RM130 each
8. Locking Mechanism (Both Side). RM150 each
9. Door Frame (RH/LH). RM50
A few RX-7 Parts to let go. Wanna clear my store room. :)
1). 20B Engine Cooler (Large) - RM300
2). RX-7 FD 2 Core Copper Radiator - RM550
3). RX-7 FD-3S Auto Transmission (Gearbox Only) - RM800 for two
4). RX7 FD-3S Burn Out FM Intercooler - RM1700
6). MSD-6AL High Performance w/Rev Control (6420) - RM900
7). RX-7 FD Intercooler for Sale - RM200
8). RX-7 FD3S Front Fenders - RM100
Cheers. :driver:
_________________________
Call +6019-3190944
Cheers. :burnout: :driver:
Joey, start to collect RX8 stuff lah...
25. HKS GD Clutch Max Twin-Plate Pull Type with Lightweight Flywheel (Latest Model with spring).
2. Scoot Bonnet, can hold up 200°c (New). RM950
3. Engine Bottom Diffuser/Splashboard. RM150
6. New Burnout's Front Bumper and Rear Bumper (Type KD-1). RM1500
7. New RE Amemiya Rear Mask (Type AD). RM350
9. Stock Rear Spoiler. RM150
11.Stock Front bumper (LH) signal lights. RM50
3. Knightsports(/MS) Front Antiroll bar (Thicker than stock). RM300
9. Point Rollcage. RM1200
10. Rear Axle 4 points Sway Bars (Rear Frame).
11. Engine Lower Adjustable Sway Bar (Engine Frame).
additional request.. door outer rubber for fd.. thanks!
email to be best price [email protected] with pic plz..
2 and 3 i want pm me best price?? thanks
got pic for bottom 2 items? my email is [email protected]
5. C-West Full Bodykits (inc. Front Bumper, Rear Bumper & Side Skirts). RM1950
you got jasma cert for yr hks downpipe? thanks
Any more Engine Harness + Dashboard Harness?
Do you have FC3S Mark 5 thermostat Neck (cover) come with water temp soket?
Front Fenders Left and Right.
Rear Axle 4 points Sway Bars (Rear Frame). RM350
Engine Lower Adjustable Sway Bar (Engine Frame). RM150
Dude, pls PM me best price for listed items.
Thanks!
bro,
are these still in good shape? what's the thickness measurement?
7. FD 99spec Front Disc Rotors. RM280/pair
Hi RERider,
How much for items below?
Do you have photo's of the RE Amemiya Rear Mask (Type AD) and the Type RB bathurst X Limited Edition Seats?
Do you have the fenders as well? Burnout's Front Bumper and Rear Bumper (Type KD-1).
Thanks.
Price added. Pls refer to front page. All PM Replied.
Cheers.
Update. Some items were sold.:rolleyes:
I will try to snap some pics and upload them. Alternatively, u are welcome to view the items that u're interested. Cheers
bro i will be making a trip up soon already.. sorry for the delay... hehe
anyway the chassis bars tt u showed me the other time? got stock?
and the u managed to find the screw,washer and nut from the original headlamp for me ? thanks a mill bro... i will drop u a call one week b4 comming.
Okies buddy no worries already reserved 1 set for you. Btw, I won't be around in KL from 09/05 till 17/05. I'll be attending the Tiesto Tour in PD on 09/05 and go aboard on 12/05. Are you coming to the Tiesto Tour?
