DIY water electrolysis to supply H2 and O2 to engine project
Depends how big is ur generator. Each size will have a maximum drawing of Amps. Normally adding baking soda is to control the amount of AMPs being drawed. If ur generator max drawing of amps is 20...no matter how much u add, it will also draw 20. But if u did not add, it might just drawing 10..or even less.
the best way is to add soda and add more plates. keke...
i plan to charge my UPS then i place at car boot to supply 240V for my generator. the UPS can last for 30mins only.
keke....
keke....
Wa very ambitious of you ar... :rofl:
Nway i think i found out why my car fc so bad, because i hook up the vacuum hose to the generator and the manifold pressure drops so it's like simulating a open throttle therefore more fuel is injected due to the drop in vacuum and screw up my AFR. :biggrin: As the fuel rail runs on the vacuum pressure to work correctly so if the vacuum pressure drops the fuel rail will increased the fuel to the manifold like the throttle is open so i guess i just busted the micro compressor theory. :biggrin:
storn u should lay the H2 pipe into the air filter hose. let the air being suck into ur engine.
I was thinking of that too. But wira engine bay a bit tight where to place the generator? infront the brake servo? :hmmmm:
I was like thinking to disconnect the crankcase hose to the main intake tube and replace it with those mini open pod if u get what i mean, then connect the generator there and when the throttle open it will suck in H2.
storm,
just my 2cent idea to share with u.
i think dont kacau or change ur air filter. just lay the H2 pipe into the air intake mouth so we can see if the H2 works fine or not with stock engine and see got saving or not. i think u can put ur generator behind the bumper which i think i will place mine at there too.
the youtube clip shows that they using the filter bottle to make the generator which is damm big. my car wont have the much space to plug that thing in.
