Yuuuhooo....? Vteckiller busy ka? Our bro here needs some after sales service
bro explain to me the differences between emanage and safc2 as it seems more interesting with emanage.you'd tuned my safc2(mivec) the other day and im thinking of taking it out as a replacement to emanage but i would like to know will it change a lot?
vteckiller bro,i wanna ask how much u charge to install + tune fuel/air and ignition timing for a original kelisa 1.0,my car is a bolt on turbo,i bought my e-manage so i needed to know how much u charge me,thank you bro
Guys, I have wideband a/f and wondering if someone could guide me on how to tune E-manage blue. I'm running firmware 1.49 (Gold) on 4AGE 20V BT. Any help will be appreciated.
Hey vteckiller, thanks for the tips. Really appreciate it. Is it true to stock BT will run too rich at full throttle? Mine goes below 12 AFR and goes down to 11 AFR when reaching 8000rpm.
Anyways, how much more power can a bone stock 20V Blacktop make with E-manage alone? +10hp?
Also, how much do you charge for dyno tuning including airflow, ignition, injector and acceleration map for E-manage?
Tuning Tips :-
If your car is N/A try set your target afr at 12.5afr
so if u can get afr at 12.5 from maybe 3000rpm till 9000rpm and full throttle that should be safe and car should make good power.
you can run 14plus at idle and and light cruising.and at half or 3quater throttle target 13.3 or around there la but full throttle try run 12's ok.surely car wont bloW!
About turbo charged
same thing on cruise and etc...but on full boost and full throttle at 3000 rpm to whatever rpm must run in the 11's afr and u'll surely be safe...
surely no blow engines..
but on turbocars u dont add ignition on full throttle ok! leave it ori if original ecu is turbo ecu or u can retard more..
n/a can add bit here and there la..not to much but a bit la..if u are good and hearing at pinging..then u can put more or else carefull..too much will blow your engine! broken pistons...its call detanation! so beware!
cheers
Joshua
Hello joshua sifu, I am wondering if you do tuning on Stinger EMS standalone ECU for 1Jz-gte engine? It's plug and play system, how would you charge?
yes, the EMS standable ecu comes with software and a base map. Can tune for different map and keep the settings for future usage.
hello, want to know if tunning without wideband sensor but using afr meter will it be ok? normally afr will be under read or over read? thanks
! who can help me!!!!!!!!!!!!!!!!!!!!!!!!where the workshop can help me repair!!!!!!!!!!!!!!!!!!!!!!
