what is mf? micro farad? Isn't that same as uF. 45mf is very small.
TQ all my friend.. refer to cybtech..
one more thing though, if the farad too high...
it'll burnt your fuse once you start your car... it "eats" first start's current...
becoz if the power cap's charge is empty, the first charge current (while you start ur car) is nearer to infinity.....
so, becarefull when you choose your power caps.
This also can be settle with proper wiring and safety relays properly assembl
which fuse will burn at first start.. i tot the cap will charge in when we connet the cap terminal to batt terminal.. and the current still on the cap even engine is not running. about pro and cons.. i think it will help the for long lifetime batt and of course improving sound quality especially bass sound.
correct me if i'm wrong
mf?? is motherf**ker....![]()
brother...brother... i tought you all gone through school....
"m" is mili, so 45 mili farad (mF) is 45000 micro farad (uF).....
i wrote this.... didn't read???
"45mF = 45,000uF and standard alt"
So, i does have their pros and cons....
more farad will make your ICE better.. but will drain your car electrical supply
If gila2 ICE mod can la use these "gila" farads...
drop la car performance.
It depends on the individual needs.
eg. me just used a simple DIY caps for my VS to stabilize my car voltage...
at the same time improve cars sound system.
my ICE small one only a 120W monoblock for one 12" sub....
caps.... accumulated around 45mF = 45,000uF and standard alt.
SQ is satisfying, not great, but still satisfying.
Mahaguru cybtech
after reading thru all your fantastic knowledge about ice and electronic lectures, what's your ice setup? Must be super fantastic sq since you are berry berry good in electronic and ice stuff, right?
btw do you mind we all here audit your ice, becos it seem quite a long time never heard anyone here mention about their "SQ is satisfying" ?
ooo i see. yes, it will happen (spark) when we connet at the batt terminal.. as i saw on my VS already. that mean we need to discharge it first before connet it again to batt. it's the safe way.
That you refering to i think it's the voltage adjuster, to fine tune the output voltage (to amp or etc)as i seen on cap, there have 2 white screw its look like volume adjuster.. i'm sure about that.. what is function that
my setup.... not even good....
all using 2nd hand stuffs and china speakers....
only thing is new is HU and wires. My amp also salvage form a junkyard and manage to repair it myself. All these... DIY it to my car... Handwork/wiring quality... bad... But after all is done.... can work... so "satisfying" only loh
as you can see here... i'm not that great in ICE (infect also poor and stingy)... but electrical electronic knowledge for it so-so due to my AV engineer experiences, so why not share it out.
Here you can point to me where is wrong.... i'll accept it if i'm really wrong, but if i'm sure it's right... i'll never stop supporting my concept. (lansi horr)
I was the bzbody in class last time... never stop asking till i understand.
okla like tat I say you wrongloh,since you say 2nd hand stuffs and china stuffs not good! A lot of reputable ice are from China. Good or not the sq still depend on "the ear" benchmark. Like a malay saying 'belum dengar belum tau,sudah dengar hari hari mau" muahahahahaha
Electronic only play a small part,the rest is tuning,then here you go back to "the ear" benchmark, ya u can use all kind of gadget to measure the distortion but at the end of the day whether you like the sq is another question. Don't listen to me as I m oni a newbie with limited ice knowledge.![]()
The is the purple unicorn of the Japanese car collector world if you will…
There were 19 Nismo Z-Tunes produced in Japan and...
