- Joined
- Oct 10, 2005
- Messages
- 588
- Points
- 5,018
ourtrunning them in the city is almost impossible, just run over them and drive to the nearest police station.
on highway then different story. you will almost 100% outrun them with a 1500cc & above cars - again, different story for 660cc kancil - sorry.
on a highway, just drive 140kmh+ or full throttle depending on how hard you balls are, after 5-6 km, you wont see them chasing you anymore. why? coz rempits are running on 2 strokes 125Z & RXZ etc, if they go full speed to keep up with you @150kmh or higher, their engine will overheat, running too lean and eventually "piston jam" or berlubang. Most of their setting is only to run max speed @ 1km or lil bit longer. Try running Kesas from Sunway to Klang and see, they wont be able to catch up. ** if you are in LDP, then good luck, hehee.
about those 4 stroke bikes they have - those 110cc 4 strokes wont be able to hit 150kmh constantly. PLUS at 140kmh +, the slightest touch between their handlebar with your side mirror will make them a real superman flying straight underneath the bus/trucks. so if they can catch up, just swerve your car and they will surely avoid you unless they really want to die.
just my 2 cents.
YES! 100% agree....2 stroke will overheat and pistonjam, 4 stroke kenot go high speed.
If LDP, just stick near near to the car next to you, see what he can do. or give him space to overtake, then when he is in the middle either left or right side of your car just swerve a little, you will see him braking and flying off the bridge = )
