Hi, i'm planning to get 1.5 block & 1.6 stroker kit for my engine upgrade.How much does it cost including installation?Do I have to change g/box,injector & ecu as well? have to register with JPJ right?
Why not go to 1.6DOHC complete engine and ECU instead of 4G15P?
yeap... 4g92 dohc is plug n play into satria... why not??...Why not go to 1.6DOHC complete engine and ECU instead of 4G15P?
mivec version, prepare 7k for engine alone... 1.6L sohc (standard wira 1.6 engine) around 1.5k can get....how much will the engine cost? does is hard get one?
Ofcoz 4G92P will be better, 4G15 design is so ancient
Normally there are 2 source of leaking from them. The rubber surrounding the door loose or damage liao OR most likely the water proof plastic sheet inside the door got holes or not...
