- Joined
- Jun 26, 2008
- Messages
- 287
- Points
- 1,516
also got 4G67 complete + gearbox without wiring
ke70??... planning to venture into drifting scene??...Well Mr.Joker...I'm kinda short on cash.And theres no way my parents are gonna buy me a car.So i figured doing the conversion myself would be cheaper.I'm just trying to make do with what I have.I was considering a KE70 but wouldn't it cost the same price as a 4g91 conversion?
gearbox can use back standard 4g13 gearbox mah....i got 4G61 n/a half cut but it auto transmission
1.8L NA mirage engine...also got 4G67 complete + gearbox without wiring
yeap.... but the risk is u might end up with a problematic car.... for example, bent chassis, problematic engine, and so on...Anicide,
At this point in time, only 4G61t or 4G91 engines is available
If I were you, I'd buy an already converted car.
Nowadays car prices are so low, I believe a Wira Turbo is only about RM20K++ rite?
4G61 NA Auto? gearbox can use back standard 4g13 gearbox mah
Are you sure the 4G61 Mirage can use 4G13 g/b?
I think putting in a 4G67 block with Evo 2.3 stroker kit will be a more worth while investment for my wira. how much would it cost? to change all the seals, wear and tear & necessary items to keep the engine problem free, anyone have experience?
evo 2.3L stroker into 4g67 1.8L engine??... wouldnt that be abit too ambitious??... a total of 5L upgrade on standard 1.8L block...
4g67 engine would cost about rm4k plus.... but the 2.3L stroker would definitely kill u, if its available....
great idea ,but after convert and plus all the mantainance fee u can buy a new car already !![]()
IMO To fit in a vr4 into a iswara needs the following below:
Chassis reinforcement using metal plates to weld on. [yes]
4 point roll cage. [not needed, not road legal]
GT wing mounted through trunk onto chassis. [not needed, but good if installed]
Foam the car. [not needed]
17" rims with brakes system upgrade. [huge rims not needed, brakes definitely yes]
modify lower arm from other brand that use hard steel. [not too sure]
But anyhow it's just a thought. it's still possible though, and it will be fun.
Im sorry to say..
but Saga/iswara is not a worthy car to whack mountain corners.. even the suspension and handling dept is improved.. it doesnt turns sharply
