My wild guess would be hiAfter cleaning the IACV (and TB, and MAF as well), I can hear Tak...Tak sound from IACV, is it normal?
But it is so smooth and responsive now.
don't think need to clean tps. And beware of rpm upside down if you dismantle tps. You need scanner to make sure it is at the right position when fixing back.
LAWCC: yo ride 3.0?
my 2.0 can give me 6XXkm on city driving n 8XXkm on hiway. still finding ways to get more km since da fuel gone up.
sb3, can if you have bigger fuel tank :)
Lawcc, did you check the knock sensor? cause that also will cause fuel problem. You can try MAF first, since its a easy fix, do clean the maf before install.
