there are alot of good workshop out there who can do B8 now days ...
colo choong is a old mazda sifu also ... he is been doing b8 for more than 10 years already...
ok....there is this indian chap formerly from cycle and carriage who is now running his own outfit in Subang industrial area. He seems to be quite knowledgeable on the K series V6 engines cos there were a few lantis with the KF-ze engines at his shop...
If you are patient, i'll try to get the details for you. Cheers!
bro if u want to go to kolo choong u can call my cousin he always goes to kolo choong ....can say alomost everyday he is there he can take u....u can call him at 019-5727327 his name is kabir ....just tell him u spoke to me n i asked u to call him to take him to kolo choong :) :)
Hey Rajie,i know that u got a B8T Monster rite...actually,im planning to buy a Mazda Neo 1.5a and convert to B8T engine...Can kindly share abit whether can the B8T engine implant into the Neo? Doest it required heavy modification and most important do it need to convert to 4WD?
Lastly,wat's the estimate price to kau tim everything?
Thanks
hey bro my B8T is not a monster la my wan was standard la....bro mazda neo im not sure how the car looks like la .... i must check with kolo choong can a B8T fit into a neo or not and if can how much will it cost ....normaly for B8T we all run fwd there is more powerfull....and is urcar fwd or rwd ???
bro kolo choong workshop is located in balakong at the moment ....but he is shifting to his new workshop which is located in cheras around end of next month ....there is going to be adyno machine also in the new workshop
hey thanks rajie...B8T at least can easily sapu all the civics or fto out there right?heheh...the car is a fwd and its look like ford lynx 2 door...
will hope you can help me to get some info from colo choong and all the best on yr studies in australia....:wavey:
bro Civic n Fto can la no problem la ....with a b8T n a good tunning n set up u can wack even GSR n even smoke and Evo also ... :) ... done it before :)
Hi Sifu Maskulin,:wavey:
can share a bit of yr experience about B8T performance? What is the hp? Better in FWD or RWD? Do the engine reliable (always give problem)? Lastly,roughly how much for the convertion?
Truly appreciate if you could share...
b8 got 2 engines one is a b8 180 and 1 more is b8 210
the difference is the 180 is using vj20 turbine n its not ball bearing and it is 180 hp(im using)
the b8 210 comes with a ball bearing vj23 turbine stronger conrods n pistons(maskulin using )
b8 gives the most power when it is in a FWD...
as for the half cut price is b8 180 is around 4.5k - 5.5k and the 210 starts around 7.k to 9k depends on what u get with the half cut (the 210 halfcut is hard to get now day)
so far im using for 1 year plus no major problems to the car .....even if the timing belt breaks also engine not affected
Check this out....
Got LUBANG find this stuff from a chop chop shop.
It is for altezza sxe10,the seller say this is high low and soft hard 4 point adjustable. some of you guys know about this stuff...
hai guys...wut the most suitable suspension for fd3s..i wanna go for fully adjustable,but dunno wut brand is very ok for fd3s.my budget is around rm1.2k(secondhand halfcut shop)ist posible to get?...thanks for yall...
