i m using bb4 setup at the front, cant clear 15x6.5 ET45 rims.need to use spacer.would be nice if using ET40 i guess.
else kindly shed your thoughts. Thanx
Where all the Sifu? Need some advise....I just got my ride installed with DC2 TypeR last model 5lug brake set + EK9 TypeR Wheels. Also replaced the Master Pump to a double layer. Brake pads are 90% and using Dot4 brake oil.
My question is:
The brake pedal feels very soft and it goes down like 75% before the stopping power takes place. Is this normal ? or something is wrong? Although when I hit that point it really stops yet I feel there is a lag in fractional seconds before I can hit it. If its normal then I have to get use to it I guesselse kindly shed your thoughts. Thanx
get the Mugen Type-C brake pad... u won't feel soft anymore....... ur rotor will tell u how hard is the pad...
so you're saying the pads are causing my pedal to go in 75% ? and not because of air trapped or something else...Erm...weird huh :rolleyes:
hehe... i oso kena when i use the 18c dics + 22a caliper....
if u say so got air trapped.. try bleeding la...
mayb ur guys brake pump too small...
Erm...will try the bleeding then..thanx
double layer not enough ah? what brake pump to use then?
aah laaa.... servo pump std lagik...
that's y la cannot give superb performance eh??
is it true??
double layer from wat car..??? EK9's 1"..???
bro jineil2en,
what master pump u suggested use on my EG...
my ride install 2 litre now with dics 1.8 + 22a caliper??
my master pump is std mended....
yes from EK
