My 61t setup now....
TD04HL turbine
VR4 intercooler
2WD Mirage Turbo Gearbox
Evo Cam
Evo stock clutch and pressure cover (got it from evo halfcut)
1.5mm metal gasket
Adjustable campulley
Double diaphram fuel regulator
bosch ext fuel pump
SAFC2
Electronic boost controller
Stock 61t piston, wiring, ecu, airflow and 390cc injector...
regularly boosting at 1.0 bar and sometimes 1.2....i dont plan to change the stock piston but
i want to know if changing to vr4 ecu and airflow can add power or not to my machine, is it plug n play to 61t wiring....injector must upgrade or not?
TD04HL turbine
VR4 intercooler
Evo Cam
1.5mm metal gasket
bosch ext fuel pump
SAFC2
