viva 850cc
n/a can use... but for wat..?? dun make sense lor...
i prefer Neo... can show off, lansi ma... hehehhe...
Lol ..neo better r.. ok.ill consider it later.. :P
i think la..he mean..what ever mod we made..still there other more power then us.. i think la..hahaha
bro jin..ive 2 question...
1.k3 vet really can inserted to viva engine bay ?? need to mod sumthing ?? do you know how much it cost ?? engine + install ??
2.im thinking to change air filter at my viva..open pod 1..got hks 150mm,200mm..,apexi dual funnel and k&n air filter..which 1 better for viva r ?? i want your opinion please..:wavey:
1. can, yup, with some minor mod... lot of sifu here oso know 1.. halfcut is bout rm7500-8500, installation is from rm1200-2200.
2. for the air filter, if ur car is manual, then any open pod u like la... nothing much difren. just get which brand u like it most... but for the best result, get those big name from USA or Japan... but if auto, get the D-Sport or K&N drop in oso very good, but if u wanna open pod instead, then i suggest u do the heat shield.
waaa..really can r..thx thx..ill do more reading and surfing bout this things..
mine is viva 850cc manual...yes i already design the heat shield for my incoming open pod..using aluminium plate + kulit kotak(i just d.i.y it la..as i have read at zero2hundred thread about open pod.) maybe will buy apexi dual funnel power intake.right now just waiting the dealer at zero2hundred got a adapter for viva..and wondering if i custom air ram/hose at ekzos shop..the power will drop or not..coz i wanna put the air filter far away from extractor.. correct me if im wrong.im new in modifying car.viva is my first ride btw.. :rolleyes:
for custom the air ram is a very good step. just take some branded air-ram with air filter such HKS, Blitz, TopFuel or J'S racing as reference(no Hotbits). diameter shld from mid>big>small... thats the best for the air flow & can keep more air inside the air-ram, then good for suction when hi-rev or changing gear, turbulence effect ma.... if possible, just custom a CAI(Cold Air Intake) into ur air box.
p/s: for air-ram, dun using Stainless Steel...
waaaa..need branded air ram..this is the problem..where can i find custom branded air ram ????
1 more thing..what do you mean mid big small ??sry..i newbie..if u find this is a stupid question.
i mean, u can copy those branded air ram design, then custom 1 to suit ur car... i got 1 might suitable to mod into Viva & Swift... but the price is rm550.... Dry Carbon 1...
mid, big, small is refer to the size of the opening, the the air storage spaces, after that a little bigger than ur throttle size...
ic woah dry carbon no wonder expensive..huhu if you dont mind..may i see ur air ram..just want to see..
I experience the fun of driving a small car like viva using stock engine, and also driving a kancil with a highly modded turbocharge engine using a TD05 Turbo. Turbo lag was significant at revs below 3k, but beyond that it just skyrocket pulling away from GTI and 1.6 mivecs.
However, ride was of course flimsy and very unconfortable, even with the Teins and especially with the 2 piece racing clutch.
I would suggest retaining your car as a fun, fuel saving drive, and maybe just add in minor mods to strengthen the body such as anti roll bars, and all the bars.
Seriously, if all you care about is performance, then ignore all the basic stuffs like dry carbon air filter ram, and straight away turbo kit your viva to a boost of around 0.5-0.7. I'm sure in the turbokit package, all the necessary parts are included.
This saves your dime and time.
ic,huhu i just planning to change air filter only..then finish..maybe paling top modify..buy a safc.
if u still want to use stock engine than this are my suggestion;
1.bigger block(850 use 1000 same piston but dif stroke)/
2.or rebore and use bigger piston using viva 660 piston and use 1000cc block and part)---ops this method will make ur car be more 1300cc -+
3.bigger throttlel body(1000 cc or bigger)
3.use viva 660 computer box (rpm >8000)
4.custom manifold and piping
