Hi,
Here is a typical cost of service on my proton iswara 1.3, which is now 7 years old:
I send my car to an authorised proton service centre regularly.
The following service was done on 4/10/2008
Major Service 180000km
Brake Fluid (Dot 4) - 2 btl -RM 19.66
Injector Cleaner 250ml - 1btl -RM17.90
Windscreen cleaner 60ml - 1btl - RM5.20
Fuel Filter -1pc -RM6.85
Oil Filter -1pc -RM9.47
Gasket Rocket CV P/ISwara (Engine Gasket, they say have to change on major service) -1pc - RM29.04
Engine Oil Shell Helix HX7 4L (Semi-synthetic) -1 btl - RM99.00
Gear Oil SAE80W90 GL-5 18LTR (Have to change on major service)- 2ltr - RM33.48
Coolant -1btl -RM28.34
Spark Plug P/12V (C52LS) (Normal type) -4pcs -RM22.79
Gasket Engine Oil Pan Drain (It's at the bottom of engine, where they drain the oil. They say have to change in every service) -1pcs -RM1.94
Labour charge - 1unit -RM90.00
Please share your thoughts on the charges above, whether they are reasonable, more expensive.. etc..
They package their service by minor service, major service according to km
I send my car to the authorised proton service centre because of the assurance that they supply genuine parts and very very rarely use other independent/ third party service centers. I'm not sure if those standalone or third party can provide equivalent quality of service.
Attached the bill as reference.
Part 2 - Brake Pump replacement
Right after the above service was done, on my way home, I found that my brake was not working. Only when I step on the pedal 2 to 3 times only the brake is activated. I called up the service centre and they said could be a brake pump is faulty
So I went back to the service centre on 6/10/2008. I had the brake pumps changed.
Cost of brake pump replacement:
Brake master pump - RM187.71
Brake fluid dot 4 - 2 btls - RM19.66
Body pump - RM260
Rear brake pump 2 units -RM116
Labour for change brake/master -RM63
I am wondering why they did not manage to check that the brake pump is leaking during the earlier service.
Body pump - RM260
