it is the trademark sound of 20v lah.... tektektek..... diesel sudah mai....![]()
i thought i punya saja
Anyone use Blitz engine oil before ?
ooooooo....like dat hahahahahai thought i punya saja
Bump:
my friend hav take dis 2 his 20v BT. nice sound halus!!!
seems like most 20V have the sound especially Silvertop, maybe already near expires.
Mine also had the sound, as long it keep running without problem, you can make any
noise.
muzhaffar, how long you using the Mobil 1? the way you drive? it's very concern me
coz I need to topup, reverse situation when using Toyota Semi.
Where he bought it ?
actually, i just bough that car about 1 month.already travel over 5k km
since i change the engine oil, i never top up and the level of the engine oil never reduce lower than 3/4..
noise.
maintain semi-syn is good enough. probably your piston rings or oil seal are showing sigh of ageing, & can't take full syn as they used to be. i've been using semi syn for the past few years and never once i need to top up. the sound you mentioned, it doesn't matter if silver or blktop, it sure there as long you use the stock intake pulley. change to aftermarket pulley, advance it, and not only you eliminate the sound but probably can increase the performance too.
owh
so, it sound of the pulley..if take away the intake pulley, there is no vvt anymore
and fuel consumption sure high
b4 this, last owner put racing cam inside the engine..
idling is worse..
i ask him to change to standard one..also put back original air cleaner instead of trumpet..
so loud suction sound..
just want a smooth and silent ride..
i've tested shell helix semi syn,mobil semi syn and Q8 semi syn,of all that i prefer the Q8 coz the engine feels lighter and more responsive...
and regarding the vvt pulley,not necessary will increase ur fuel consumption,depends how u tune it,i chge both my pulley to adjustable and the car now save more fuel:proud:
juz my 20 baht,dun shoot if wrong...
fuh yo... changed adjustable pulley. tat y ur car so powerfull hahahahha
Q8 oil 10/40W .. i use it.. very good.. so far very good ,...
thanks
