advise needed. just bought an ee100. read abt it.
alex27
ive been a honda man eversince i had my license. ive been driving eg6 n ek4 for a while. d ek was my daily car, so recently just sold of the civic ek. n i bought a ee100. really impressed me on my 1st test drive with th ee100. much better than my ek. stability, handling comfort. but lack of power hehe
Just needed some advise on the ee100. are all suspension n arms useable from the ae101 the 1.6 version. N also each time i switvh on the air con, the car really looses power. now i go for toyota...
yes.. it can be interchange... If feel under power... so upgrade to blacktop la... It will make it enough... hehe...:biggrin:
aiikkss... 1st time saw people impress the toyota was perform good in handling, and stability le... even better than ek wo.... wow... Banzai TOYOTA!:adore:
welcome to the toyota world.
yes all arms/susp part same with 1.6 variant. better u straight buy a half-cut (4age) and port all from that h/cut to ur car, save time comparing to replace 1 item by 1 item... hehehe... poison time:nurse:
mind if u guys share with me what parts are interchangeble with the ae100?
is the 2e engine tat underpower? i kinda like 4e turbo better hehe
bro alex if u want to use 4efte also can no need to ubah 1 tapak mounting near pulley but the power cannot beat bt/silvertop. fuel consumption also more than bt/silvertop because the body heavy.
for ur info the part which can interchange with 2e engine only gearbox, alternator other except head unit like monifold dll. because 4efte is injection engine. 2e is carburetor.
use 3sgte lah. but i think jpj cannot approve 1.3 car upgrade to 1.8 unless ur car now 1.6l body.
Yea i wana rasa Turbo, been playing NA for a while now vtec hehe i heard 4e fte is very economical. No need ubah mounting? if 20v must ubah mounting. am i rite?
i mean parts interchange between cars like ee90 or ae101 for eg brakes, etc. Thx yea
4EFTE if in Toyota Startlet, the FC will be good. But another round if in AE100 and underpower too.
20v just need change the position of mounting, but not a big problem what! Many of us also change it... no problem at all pun. If seriously want to play in force induction, why not put in 3SGTE from ST205 halfcut engine? Power until you will smile... or else buy supercharge then change to turbo... easy also ma...
brake (front only), ball joint, driveshaft, engine, suspension, clutch and alot of part as wellcan be interchange...
can be approve la.. but with some $$$ lo:listen:
i even saw a SEG 1.3 converted to 3SGTE from ST205. It is 1.3 --> 2.0 le... can be approved le...
yes rite no need to ubah tapak if u use e series engine. if u use a series to ee code body need to ubah tapak la.
ok thx guys..
Bump: 20v how much power it has, HP? torque?
which is better black or silver top?
better than vtec?
better than vtec?
just my 2 cents...
1) 20v how much power it has, HP? torque?
standard power on paper is 165hp for blacktop and 160hp for silvertop...torque remains the same at 162Nm
2) which is better black or silver top?
hard to say which is better but i feel the blacktop revs slightly easier due to lightened con rod and flywheel (correct me if i'm wrong)
3) better than vtec?
this is very subjective as it would depend on which engine you're comparing and what you're comparing but if you're comparing same displacement and terms of power then its about the same though the vtec would have slightly more power. have managed to keep up with some civic ek's and integras. my engine is stock mind you. :)
just my 2 cents...
1. yes, torque are same meh? hrmm... really?
2. blacktop also have lighten and more balancing in crankshaft. ITB also not same, blacktop are bigger.
3. yes stock Blacktop are better than stock B16A.
Ok. Hey my corolla d speedometer is not working. I seek a mech he said my engine is run by cable. Can any explain wat it means? D last time my eg6 speedo not working i just change d speedo sensor. I saw d 2e gearbox has speedo sensor too. Huh. I'm lost. Any1 elaborate? Btw my ee100 no rpm meter,can install rpm meter?
ya simple cure for your problem + upgrade power -> Transplant...
get a half-cut and transplant engine and all those compatible parts (dashboard,suspensions,etc)
