- Joined
- Feb 14, 2007
- Messages
- 66
- Points
- 1,506
Dear Sifu's and Guru's,
I really need advise on this prob...
I started up my a32(3L)this morning without any problem but while I started to cruise on road, I felt that it was more heavier than usual and the engine dies off. I try to start back but when I release my leg fm the pedal...the rpm meter drop to "Zero" and the engine dies beck. After several attempt I manage to get the car to run but I still feel its more heavier than usual and lack of power. FYI...I just service on the 23/12/08...but never change the plugs. The plugs has never been change for quite sometime. Is this prob cause due to the plugs? Or I found my air intake manifold slightly crack....is it due to this..
Pls advise....If its due to the plugs....im going to change it later during my lunch break.
Thanks & regards
Thanks & regards
...Anyway are you using a32 too...do u ever had any experiance for engine knocking sound?..
I'll be letting go of my pride & joy for something new to work on
