T will be stated there if it is shown in yr excise paper, puspakom report or yr geran if it has been endorsed.
Supposed to be BT...not directly 4G93T...is like 4G93 BT 0000-0000-000
depends on your engine, if the block is really 4G93T, then it wil be written there...if your block ain't turbo block, there wil be no BT...beside BT if not mistaken there is other code showing it is a turbo block, but forget wat was tat...u can go google and search for it...good luck
my engine GSR code at geran when potong tulis 4G93P-XXXXX... hmmmm:hmmmm:
so turbo block have BT..
if dont have BT then maybe block from non turbo install at turbo engine..
thanx ya bro.. now know to search turbo block..
Bump:
93P usually for local 1.8 engine..
or ur engine is bot..
Bump:
if 4g93-BNxxx from what engine arr? local engine ke? saw it at my friends engine
Bump: if 4g93-BNxxx from what engine arr? local engine ke? saw it at my friends engine
Sifu of all there, many thanks for your help, i wanna to endorse my engine rite now but dunt know where to located it. Appreciated your help. Thanks guys..my serial is 4G 93 BT xxxxx ah ha..truly Turbo block..!!!![]()
after done some looking at my friends GSRian, found that not all the no. starts with BT.. example some starts with CC,BN,BT etc etc... also already confirm that my engine also is GSR turbo block, but still at geran tulis 4G93P, at engine only state 4G93-XXXX. happy modding![]()
. Couldn't find the parts for CS3A in the...
