Mivec gearbox or EVO3 gearbox??
zac
Johor Bahru
Dear all, now i'm suffering clutch slipped and spoiled synchronize gear for my current mivec gb as it can't afford after i upgraded engine...
So now, if i fix the synchronize gear and replace racing cluth will cost me a bomb and might not last long either, in that case, would it be advisable to use ori evo3 gb? since it's twin sync, lsd and ori clutch can hold 275bhp turbo power, should be piece of cake to handle my >200bhp NA...
The problem is, some said mivec gb is match perfectly with mivec setting, if we change the gb might result in power loss, is that true?? can expert advise me about the difference if i use a ori evo3 gb like gear ratio, final drive? would i lose out to mivec gb or lead to any other hardware failure?
Is evo gear box 4wd?
Lock to 2WD u will lost 30% of power...
I suggest u try to reduce the ecu setting to lesser fuel to reduce torque!!!
This might help geh!!!
Don't scold me if i'm wrong...
Coz i use o paly my VAFC all he time whenver i feel no statisfy!!!
too bad my clutch slipped problem not too serious during pick up, but stuck at 3/4 gear hi rev... got burnt smell...
whaooo......
This is bad...
My experience on clucth slip is during 2nd gear 8200rpm change to 3rd...
The sound like droooookkkkkkkk......that's with exedy 3 puck semi-race!!!
After all flywheel teared!!!
Try to take risk to dismentle ur gearbox to check what is the prob...
For me may suspect the 'plate' may not suit with ur clucth!!!
The spring force isn't enough!!!
but last time no such problem leh... furthermore the sync is memang spoiled already... Even i just replace clutch plate only also doesnt help much... is BR clutch ok? so cheap, only RM380
As i understading on clucth, plate should change together with clucth disc!!!
Plate pressure have life span...
I'm not sure bout the BR!
Check out with ur foreman...
Comfort std clucth if i ain't mistaken only have 2...
1 is exedy(RM350) & another is ori Mit's (RM800)!!!
And another common things is...mit's always spoil the sync gear...
Even mine LSD track g/b too!!!
Jack, are you sure or not? My leg is already painful and tired using my current clutch set..yours is unimaginable.
Zac, your mivec is >200hp? Very powerful indeed...what modifications that you did to your engine? Mind to share a bit...?
actually the syncro quite cheap but the workmanship for disassembling gbox and operate it makes the cost high.. better rebuild back the mivec gbox bcoz syncro (thin copper piece) only torn meaning that whether u will face difficulties to shift to the gear or it will stuck on that gear when u shift.. i think this happened bcoz of the insufficient transmission oil or haven't changed it for quite sometimes or using inappropriate transmission oil or simply bcoz wear n tear time already..
i have change to exedy ori liao...
Bump:
i use LSD Motul gear oil...
1L round RM80...3L almost RM300 if not mistaken...
Beh tahan liao...
I think ligther or lower viscosity will easily spoil ur gear right!!! Coz friction increased!!!
But also driver depends!!!
Somehow...if u wanna tune up a car with >8000RPM...should be very tough already
More difficult long term street use!!!
I still think it will be better value to get a E3 gearbox, as i sicked of fixing here and there... also a better gb can leave me more space to modify in future right...
Btw, i thought >200bhp is less than 200bhp right?? actually my car quite weak lah, no need to mentioned what have been done...:biggrin:
I need more info on the differences, did anyone tried it before? i knew is common for gsr changed to E3 and it should be no pro for a mivec either...
I should be more heavier...in term of weight!
How ur statisfaction on 70% of 150WHP?
just nice for street use... and not so easy to race against others... hahaha
BUMP FOR MORE OPINION!!! i already asked my mech, fix synchro gear need rm1k with all labour in, if wanna change clutch then need to buy another set of clutch... will close to 2k spend.
If i use E3 gearbox with ori clutch all in, also cost around rm2k... and i still able to sell my mivec gb to others right??
so u have to spend 3k then earn back 1k(sell MV gb)!!!
How bou rojak gear into ur Mv GB?
My mech said only RM2k needed for E3 gb conversion... but really eager to find out whats the differences before i made up my mind.
I may stop u to take risk...
even gsr isn't statisfy the 70% after locked 4wd gb...
U may cheating urself with higher final drive...
& i do admit that...Mit's 4G9X Gb always did that...
Even GSR06 just change it on 5th gear!!!(Sorry...play tek bao)
U see...this isn't that easy that part can be fit with >8k rpm...
even Evo gb doesn't!!!max 7600rpm...
Driver dependant!!!
The application is for turbo but not NA...
The main contributor is the air-fuel ratio & boost so that make u feel ligther rev...
In fact, NA lesser torque & hp...
I can bet...more or less not mch diff.!!!
U know, mi LSD are even heavier than urs!!!
since you all talk about gb..
my gb spoiled synchronize gear at number 5..so now need to hold by hand...:adore:
so do any buddy tell me where can i get that?
is that same with 4G1x?
how much it cost?:idea:
Bro Jack, as long as i wont lose more power than current gb will do... all i want is the durability of 275ps gb and ori long lasting clutch... if i upgrade my current one, i would have to spend a big sum every 2 yrs...
