me worse la......im driving 660 kancil N/A only....![]()
use intercooler to get cooler air meaning denser air meaning a bit more power.
or to prevent detonation or knocking.
r u still using the interheater aka intercooler behind the radiator one?
if no knocking occurs, then no necessity to upgrade the intercooler,
unless u want more power
how it feels after upgrade the intercooler.i dunno coz im still using std ic![]()
...and what you mean by detonation and knocking? noob about itany absorber and spring can suggest??? my car ford lynx Tx3 using a B8 turbo... absorber which i currently using can witstand the B8 power... when accelerate the car swing swing left n right.. TQ sifu-sifu
wat adjustable?? coil spring ma?
Quote:
Originally Posted by azameel http://www.zerotohundred.com/newforums/images/easyblue/buttons/viewpost.gif
azameel how high you boosting? mine now still 0.5 but wish to boost higher..i thought the hotter the air is better..hot air keep the pressure high...or the intercooler to prevent our turbo fan from turning to red...and what you mean by detonation and knocking? noob about it
i think adjustable absorber can withstand the weight of b8 engine and keep it from sway when you boosting...ur problem same with my friend..his car ford tx3 4 door coupe with b8 engine..when boosting car sway to the left..mine already using adjustable but only in b6t engine..never sway at all even when boosting..gap between fender and tire less than 5cm if not mistaken (but tire never touch fender even i hit bumper or pothole)...
azameel how high you boosting? mine now still 0.5 but wish to boost higher..i thought the hotter the air is better..hot air keep the pressure high...or the intercooler to prevent our turbo fan from turning to red ...and what you mean by detonation and knocking? noob about it
my boost meter show 0.9 but i don't think my meter is correct..previous owner said he set just 0.5 boost
cheers
