Satria Neo 1.6 campro engine. Can we do anything to improve the pickup?
Zidane
Guys,
For the normal 1.6 campro for satria neo (not IAFM), can we do anything to improve the pick up?
after market Filters? extractor? Exhaust?
regards,
well other than that..
PnP your intake manifld and throttle body... (sifu's correct me if i'm wrong)
piggyback/standalone
lightened crank pulley
high cam
fuel regulator
semi or full racing clutch
Bolt on Turbo
many thing that you can do with your campro engine... and after you have explore the power off campro and yet not satisfied... 1 thing for sure you'll think bout tranplant hehe... trust me you will hehehe
Reduce the weight of the car is the most effective way, exp: light weight flywheel, light weight crank pully, take out all un-wanted things.
Use the engine power effectively, by understanding the power curve.
Base on the dyno chart, the best torque output is between 4,000rpm~5,200rpm, every time you shift gear with in this range, the pick up will perform more better. Because this is Campro engine performance.
Thinking using less fuel and have more torque to pick up, there is no such thing :hmmmm:
Ofcourse, Diseal engine can do this (powerful low end torque), but you can't go faster.
can increase compression, squeezing more power without any increase in fuel consumption
increase ignition timing. make sure u dont over advance it and end up knocking.
this can extract FREE extra hp without any extra fuel too.
use synthetic engine oil to reduce engine friction and get more power. use low friction piston ring to reduce friction and get more power. lighten ur engine and use lighten crank pulley. all of this can extract more power without using extra fuel. use light weight alloy rim also can help.
