hi, friend.....now i just starts play e- manage with my svt.. have any sifu help me?? bcos i lean to tunning myself....hehe...
Mind to tell us the phrase "lean to tune" is what mean? :hmmmm: I bet you miss typing kua.. Learn to tune, isn't it?
If want to self tune, 1st step & important step is you need to have at least a wide band O2...
Not necessary to have Wideband sensor to tune it if you know the trick and have enough experience.
Well.. Mind to share your experience? I heard that you can self tune & made the map for the standalone ECU as well... So yours experience will be useful for us, if you manage to share with us. Anyway... me kinda noob in tuning.... Every time got to find tuner for solve it.
You got to have something to tune then only you can learn to tune. Mind to tell what is engine management that you're using? I'm seriously curious to know. Sound like you do have advance engine management. Every time got to find tuner to tune? why? Engine management setting won't reset itself and it's not necessary to tune it all the time.
As long as you got it right, that it.
what would u like to knw about e manage blue? i can share u some simple tricks wid e manage blue.. frankly speaking its a very simple device. and do not have much parameters to play with. you could pm me ur email and i can email u a copy of what i get frm my friend.
and u do need a wide band if you would like to be accurate. else u can use those narrow band autometer thingy. at least better than none....
bro.. please don't run away from other people topic le..
Anyway, I didn't mean go to tuning every time... I mean if i done anything on engine, then want to up a bit... then this time only i go to find tuner (example change Turbo, injector and etc)... Beside, means that I don't know how to setting ma.
So please let's discuss in this topic back... I hopefully you may teach us some trick in tuning field. Thanks
1 of our bro here said no need to use wide band also can be tune properly wo... So i think we better wait he to guide us depend on experience that he got le
bro EG9, please teach us le...![]()
good discussion. just hope somebody dun keep on shooting his own feet. sometimes less is more.
sorry ar offtopic..hahaha..i know nuts about ECU tuning. juz used before TRD for AFM and Buddy club for MAP. both juz toggling the preset map...hehe
Good point there. but too bad, someone is prefer to shout around pointlessly.
To topic starter, it's advisable for you to plug in the serial connection from your e-manage to your notebook and get the e-manage software to online. Take a look at the fuel and ignition mapping adjustment. then let us know what do you want to tune, you can print screen the value and share with us, we may able to guide you how to do it but of coz you need to know how do you want your engine to behave 1st.
The reason we tune because we have objective to reach such as better ideling, better AFR and ect....
RUN FROM TOPIC??? No, I never....the reason I ask you those question because it's related. Why ? can't share with us what you have in ur car? or it's "invisable" tunable stuff that sit in your car and can't let other ppl see?
You need to have something tunable before you can tune, you can't tune stock ECU. You don't even know what is in your car, how are you going to tune it? (Turbo Change, Injectors?...up abit? up what????)
You don't even specify what car that you're driving, with what engine and manage by what ECU, how do you expect me to to know?
Nobody going to say anything if you don't know how to tune, but at least specify what is you running on and what is the tuning problem that you're facing?
Then we have problem to solve here. I'm more then happy to share if someone is serious and dealing with serious tuning matter. I like to solve problem but not just talking without any direction.
hehe...thx to all my sifu....but now i need to know 1st,what is narrow band autometer & wide band? ......1st i will find tuner to install & tuning..afterthat i wish to learn tuning myself. so need help lo...
correct correct,only share inputs and knowledge if any.. bro eg9, got a noob question to ask, when u say e manage can improve response n idling on svt, what about bt? coz my mechanic argue that map is easier to tune than afm, but i think the other wise, but based on general knowledge, coz what i know is svt comes with loads of performance parts (especially management and ecu) while bt has very little, mind to share more? izzit due to the ligthened internal of bt that it can't go hi rev compared with svt, or simple fact that svt runs on afm hence easier to tune?
On engine management side, no matter blacktop or silvertop, engine management system will still act the same on the both of this engine maybe the adjustment that you do on it is is slighly different.
Basically BT and SVT share the same peformance part. You won't notice any peformance part specific it's for BT or Silvertop. It's just specify for 20V 4AGE mean it's for both. It's the same.
Yes, you did.. You didn't answer to the person who question up but instead of keep questioning me back. No mention? Yes, I do use the SAFC 2 only. I know the stock ECU definitely cannot be tune la. Why i need to mention to you? Since i not asking you how to tune my car!
Anyway... since you state "You don't even know what is in your car, how are you going to tune it? (Turbo Change, Injectors?...up abit? up what?????)"... So now see how u gonna tune it.
My engine spec:
Block - 4AGE 16v - 140ps
Piston - 82.00 mm - lo com
Bearing - King Race Bearing
Rod - BC con rod
Crank - stock supercharge
Turbo - HKS Garrett 2530
Injector - 510 cc
Intercooler - Custom
Cam - TRD 272 in and ex - Lift 7.5 - Ex. 98° BTDC. In. 102° ATDC
Spring valve - HKS
Valve - 32mm intake and 27.5mm exhaust
Map sensor - supercharge
Fuel Pump - SARD 280 lph
My now SAFC setting is:
1000 rpm - -10%
1600 rpm - -8%
2200 rpm - -5%
2800 rpm - +2%
3400 rpm - +5%
4000 rpm - +10%
4600 rpm - +12%
5200 rpm - +12%
5800 rpm - +10%
6400 rpm - +11%
7000 rpm - +13%
7600 rpm - +14%
8200 rpm - +14%
Anyway I know Narrow band can be use too... But why i said need wide band is because you can tune for more power, closer to the edge, precisely monitoring Air/Fuel ratio Boost, EGT, RPM and throttle position datalogging
Bump:
Narrow band is Basic Air fuel meter lo... Got show rich and lean only...
Wide band is Advance Air Fuel meter with showing the exact digit ratio...
Autometer is a brand name...
Anyway please view below link for more information:
http://en.wikipedia.org/wiki/Air-fuel_ratio_meter
Half of my speedo now is in the dark.. Any one knows where to get the replacement bulb or the...
