Mivec Modification
last time i m using Vafc2 tune by HVracing.(engine mod in another shop). which is confirm enough fuel to supply.mivec stock injector is larger den 1.8 dohc. later gt a damm thief wann stole my car, but not sucess den he run away my vafc, rsm, apexi timer, shift lamp.;later decide low profile so buy a emanage n install by torqxx racinxx. den tat guy say u nd buy additional greddy injector harness n ignition harness. later on say u injector n pump canot support. i think?????? WHY???? coz ago tunning in HVracing can, but torqxx racinx canot? later i buy com cable to connect my laptop n emange. den mapping back. i oso gt monitor engine knocking by by using dianogis. by using apexi timer, u can easy notice ur A/F. but maybe oni gt 75% accurate.later wif sum drive, u check spark plug n c de carbon to analyze rich or poor mixture.
lastime standard mivec canot rev til 10k rpm lah. standard ECU. now oso standard ecu. gt rev cut. by the way u use original mitsubishi timing belt(sumbody use toyota which is a bit narrow) is not seem gt problem.
i using rsm G force sensor n put car weigh 1200kg. horsepower is 230hp but I M NOT BELIEVE lah. i m clocking 6.5 sec 0-100kph, use oversize tyre205/55/16.
Bump: hahah bro kroolada, high cam for mivec gt discount or not, eco no good. budget less n i dream every nite the high cam. but y mat speed cam so expensive?
not sure but money n life span is a problem....i think if wan 300 hp better play gsr or evo. fully mod mivec canot win fully mod vtec in the end, and i accept the truth .but i enjoy my high torque n high rev mivec coz i m not always meet full mod vtec in road:thefinger:
hahaha then to play gsr i rather play mivec turbo...n beside i came from evo..just sold off my evo3 n playing with NA now..just for a change
Can a mivec reaches 300hp like Vtec B20a
maybe can , if got big budget wanna try this project
300 hp mivec parts list : :idea:
1) custom stroker kit 2.0-2.2 cc
2) high compression ratio 15.1 and above
3) runs methanol
4) full dry sump system
5) 50 mm ITB ( 4 THROTTLE )
6) mega lift cam , duration 315-325 degree
6) fully race coating ( all parts )
7) race header ( 4-1 )
Bump: Bump: hahah bro kroolada, high cam for mivec gt discount or not, eco no good. budget less n i dream every nite the high cam. but y mat speed cam so expensive?
for serious buyer can contact me , special discount will be given
sms / call 017 6917136 :biggrin:
why matspeed regrinds cam expensive :
1) proven performance all kind of motorsport
2) the machine cost hundred thousand or less
3) :sleep::sleep::sleep::sleep::sleep:
3) runs methanol
hahahaha confirm king of SDB di for N/a set up...Kroolada dont forget Dog Box....hahahaha
cant imagine running my mivec with a 2.2l stroker with 83mm piston....fly to moon
why wanna run dogbox , i used auto powerglide 2 speed
less gear and full throttle all the way , no more miss shifting :driver:
after install highcam n valve spring, enlarge intake n exhaust port is do as oso? intake manifold oso change? gt higher final gear for gearbox?
Bump: wat is mean full dry sump? no engine oil? :hmmmm:
hahaha then can play open cartegory di....hahaha rev all the way till finish SIC track
trust me there are alot of them here...n some of them i have met also....the person who took my evo engine also a member from here n a cop to :P...hehehe
