where can buy & install piston for bot??
walao !!!!!!!!!!!!!
nvm forget it :rofl:
but its better to get wiseco forged pistons
few reasons
ur machining , metal gasket and other charges are the same
regardless its forged or non forged
u build ur block only once
so if u change pistons, just pt in forged once n for all
yup...
next time first :)
because...actually my car now already low compression and using stock piston...
bro u can use 2pcs more thicknes metal head gasket to low ur compression ratio!!! more save $$$!!! he..he..
2200 piston alone..4pcs piston and 4set piston rings and piston pin..
to install need to rebore rm200 plus..
then buy gasket,etc..etc labour around rm1k plus...
so ya 4k plus total damage...
yups..
then might as well change conrod together..we have pro H beam rods...for your car..RM1800...kekekek
then race series bearings...rm680...etc..etc...
KOYAK:biggrin:
yups..
KOYAK:biggrin:
sound like 2 bar also can tahan kekeke
wow u must be crazy! :listen: heheheh
orang sabah is gila ma.. lolzz
tapi lama lagi la.. BOT 1st.. see hows going...
because i saw BC got 272 turbo cam, valve spring/ retainer, valve, conrod, crackshaft also ada... stroker tu...
if project no body i will find but u :):adore::adore::adore:
1st week july i back kl, i cari u discuss tu BOT ok? cheers bro
stroker no need la..
u change piston and gasket ok d la..
